Transmission not working with USB HOST CDC using the STM USB stack, STM32CubeMX, the dev board B-L475E-IOT01A (STM32L475 Discovery Kit)
Posted on April 11, 2018 at 21:30I installed the USB HOST CDC on B-L475E-IOT01A, used the STM USB stack and I followed the UM1720 User manual STM32Cube USB host library. When I connect a USB CDC device, everything goes well for the enumeration and c...
STM32-MP3NL/DEC libraries
Posted on April 25, 2018 at 20:10Where to download STM32-MP3NL/DEC libraries?http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-library-expansion/stm32-mp3nl-dec.ht...
Send multi-packet data with USB Host library
Posted on December 02, 2015 at 18:22Hi, I'm using the STM32F407 with USB Host library, in high-speed. I want to communicate via USB with a smartphone. When i send a packet of 64 bytes everything works. If I send a packet, for example, of 94 bytes, t...
vlr by Associate II
  • 1361 Views
STM32f4 discorvery, fatfs, SD card problem
Posted on March 29, 2018 at 15:54Hi all,I'm working on getting a discovery board working with an SD card. I'm using CubeMx v4.25.0 with package v1.21.0.Hardware connection is validated and is correct. I run into a problem when I try to open a file. ...
JOK K by Associate
  • 1424 Views
Trying STM32f407 DFU. no luck
Posted on April 25, 2018 at 07:29Hello! I'm trying to get DFU works on our customized board.I tried to use internal DFU Bootloader, using BOOT0, BOOT1 pinsI connected some pins and made BOOT0  HIGH, BOOT1 LOW and plugged in USB Cable, No Luck!Comput...
How to enable USB HHID mouse external feature..?
Posted on April 25, 2018 at 06:340https://electronics.stackexchange.com/questions/370577/how-to-enable-usb-hhid-mouse-external-feature i am using this product Smart Cat PRO MOUSE(GP415U-5321), i am attached to my STM32 evaluation board. Normal opera...
Jesu by Associate II
  • 819 Views
Ethernet Rx Interrupt Issue on STM32F4
Posted on April 24, 2018 at 03:32I am currently using a STM32F407 board, with ethernet enabled in Interrupt mode, for the most part it works fine for UDP , I have the STM communicating to a another device via UDP using a switch, and in response to t...
HAL_ppp_MspInit in library project
Posted on April 24, 2018 at 15:00Hi guys,I've just started working on an ST32F4 mcu, with the ST32F429I DISCOVERY demo board.Just one question about HAL_ppp_MspInit() functions: can they be implemented in a source file of a library project?I've trie...
