How should we start with USB FS to read out a QSPI flash memory without filesystem on an STM32F7 device?
Hi there,recently we successfully implemented our functions to read from and write to our QSPI NOR flash with an STM32F746VG customized board. Its working fine. From now on we also want to get the stored data via an windows application over USB from ...
Resolved! STM32L432KC SRAM2_BASE incorrect in HAL header?
Hi,The file stm32l432xx.h defines SRAM2_BASE as 0x10000000, but the datasheet https://www.st.com/resource/en/datasheet/stm32l432kc.pdf says that SRAM2 starts at 0x2000C000, is this a typo in the HAL header?Thanks,Jacob#STM32L432​ #Hal​
jschloss by Associate II
  • 2560 Views
STM32F7 Cube Middleware bug SDcards > 4G
The USB/MSC/SDcard middleware code does not work correctly beyond 4G due to a bug.My code that is seeing the problem is based on an older version of Cube, but the ST code appears the same in the V1.12.0 cube code I downloaded today.The SCSI protocol ...
