Implementing lwip + FreeRTOS in STM32L152
@I am using STM32L152RE Nucleo board for my development. My goal is to bring up a PPP connection using LwIP stack in a FreeRTOS environment. The evaluation board I am using does not have an Ethernet port. I will be talking to the modem serially. Cube...
Jagadish by Associate II
  • 911 Views
DAC-USB Implementation Problem
Hi, I am using Nucleo F303re with STM32 HAL Libraries built by STMCubeMX in order to implement an USB Audio player with bulk transfers. I changed the USB-CDC code a little bit to implement my application. I receive the data in the CDC-Receive-FS func...
B??el by Associate II
  • 3504 Views
Need demo firmware for stm32303 "E" version Eval
Unit came with demo loaded in flash and worked fine, I reflashed some test code and now I want to put demo back.I downloaded STSW-STM32124 which is the STM32303C "C" version demo firmware and compiled and loaded fine with IAR, but will not run. Co...
FJB2069 by Senior
  • 2178 Views
Multiple USB descriptor ( RNDIS + VCP)
Chip set : STM32F413xxI would like to implement RNDIS driver + VCP(FS).I wonder that usb descriptor is available or not for this combination.Descriptor was modified for this.VCP was enumerated but RNDIS was not enumerated. error code is 10 from windo...
YChun.5 by Associate
  • 803 Views
Resolved! STM32L4xx HAL Library USB bug. Function USB_WritePMA does not work properly when compiled with "-O3" option.
I used latest CubeMX version and found another one bug in stm32l4xx_ll_usb.c generated by it. If you will compile code using "-O3" optimization level, function USB_WritePMA will not work properly. /** * @brief Copy a buffer from user memory area to ...
