Ethernet communication
I am using Ethernet transceiver "LAN8742A-CZ-TR" for STM32F427ZIT6.Does "STM32F427ZIT6" support the mentioned transceiver and to what pins of STM32 should i connect the RMII signals?Thanks in advance..
DKS by Associate II
  • 1224 Views
TCP Client Problem
HiI'm using netconn api library to make tcp server and client on stm32f746Tcp server works properly but client can not connect to server and it returns error code -4 (err1) which means routing problemI don't understand the reasonhere is my codestruct...
afra by Associate
  • 973 Views
CAN and USB (vcomport) together (CAN USB bridge)
Hello ,I need to design CAN and USB bridge .which micro controller should i be using?.and i have tried STM32l4r5zi, STM32F407vet6, STM32f373 but none of this got worked, every time i have to deinit the CAN and run USB. is there any micro controller...
SKira.1 by Associate II
  • 1373 Views
STM32L1 HAL has compatibility problems on I2C API.
Hi.I have found the STM32L1 HAL generated by CubeIDE doesn't have compatibility with the one generated by CubeMX.For example, According to the UM1816 "Description of STM32L1 HAL and low-layer drivers", I2C has API like following :HAL_I2C_Master_Seque...
Takemasa by Associate III
  • 1718 Views
