STM32F407 ethernet library
I wanna use Ethernet with STM32F407 MCU. I found only a standrad peripheral library on st.com site. Where can I get the official support library for Ethernet?
sminder by Associate II
  • 1664 Views
CMSIS RTOS V1 : DSP and semaphore issues
Hi,I am using STM32F405, STM32Cube_FW_F4_V1.24.2, STM32CubeIDE, CMSIS RTOS V1, and CMSIS DSP library. I would like to use FFT and semaphores in my project.Does semaphore not work with CMSIS DSP? I know I can get semaphores as well as the DSP related ...
DLim.16 by Associate II
  • 2137 Views
IAP over UART
Hello all,I know this has been probably done to death,but Just a quick link or some pointer if possible :I am using an ESP8266 to flash code to an STM32F103 over the UART.Basically I want to do what the "Flash Loader Demo" STM utlity does, by using t...
TFern by Associate III
  • 1837 Views
STM32 MCUs IDE
Forwarded fromhttps://www.embedded-computing.com/home-page/rt-thread-iot-os-launches-rt-thread-studioRT-Thread has launched RT-Thread Studio, an integrated development environment for the open-source RT Thread IoT RTOS. A customized version of the Ec...
PPete.11 by Associate II
  • 1027 Views
DFSDM output array values are wrong
I am using STM32F413CG MCU , I'm trying to interface DFSDM to have audio samples to send it to I2SI am running DFSDM audio clock at 61.44MHZ and clock divider is 20 , FOSR = 64 , Sinc 4 Filter , right shift =0 my problem is that DFSDM output array va...
0693W000000V4ebQAC.png 0693W000000V4eRQAS.png 0693W000000V4eHQAS.png 0693W000000V4eCQAS.png
HNabi.1 by Associate II
  • 1111 Views
Doxygen bug in usb_device.c.
Getting some doxygen warnings:usb_device.c:94: warning: unbalanced grouping commandsusb_device.c:98: warning: unbalanced grouping commandsI think the file is missing a couple of @defgroup or @addtogroup./* USER CODE BEGIN Header */ /** ***********...
MSipo by Senior II
  • 818 Views
HEX to DFU without files in C#?
Hi everyone,I'm working on an app to configure an STM32 based DFU device and I don't want to deal with the file system. Everything works now except one step, going from Intel HEX to a DFU image directly so I can write it to the device. The ST DFU ima...
DVoro.1 by Associate
  • 1035 Views
