What is the right way of porting amazon freertos?
Hello,I tried the poritng guide but it took forever to fix the missing and conflicting paths, and it's not clear what to compile and what not to.I want to have mqtt + lwip + mbedtls + PPPOS (I can start with Ethernet as a start).I can use other SDKs ...
AWahd.1 by Associate II
  • 891 Views
FreeRTOS on STM32
I am new to ST Micro development boards and environment and want to learn FreeRTOS on STM boards. Which board should I buy to start with? Does ST micro provide development boards as a sample to learn ?Thank you,Prachi Patil
PPati.4 by Associate
  • 1479 Views
Resolved! BSP_AUDIO_OUT_Play ends up in Default_Handler
Hello,I try to play a sound using stm32h747i_discovery_audio.c. Initialization goes well void CAudioController::AudioOutInit() { BSP_AUDIO_Init_t audioOutInit;   if (!audioOutInitDone_) { audioOutInit.Device = AUDIO_OUT_DEVICE_HEA...
ALevc.1 by Associate III
  • 1934 Views
Most up to date SVD for stm32g474?
The SVD file on the STM32G4 series resources page is out of date, hosting version 1.0 of the SVD file.It looks like the most recent SVD provided by the STMCubeIDE (generated 2/20/20 with version 1.2), has a number of errors. For example: SCB is liste...
TBlak.1 by Associate
  • 3144 Views
Is there a bug in the HAL USB HID mouse code?
The type definitions for HID_MOUSE_Info_TypeDef in the latest usbh_hid_mouse.h file in the STM32L4 package defines the x and y fields as uint8_t. The STM32Cube USB host library documentation says they should be int8_t. The USB specification seems t...
AWolf.8 by Associate III
  • 1892 Views
