Resolved! X-CUBE-USB-PD examples compiles errors.
When I am trying to compile project Consumer_DRP_RTOS from C:\xx\X-CUBE-USB-PD-master\STM32CubeExpansion_USBPD_F0\Projects\STM32F072RB-Nucleo\Applications\USB_PDI get a lot of errors. I managed to eliminate some of them by adding header files to the ...
Eremizin by Associate II
  • 2999 Views
Project with STM32F439VIT6. After activating Ethernet (DP83848) USB DEVICE CDC (Virtual com port) works not more. Can anybody suggest me where to look?
I make a big project with F439 MCU and there are many things on the board like WiFi, BT, EEPROM, Flash, GPS and so on. The latest thing I made was activating ETH and it works good at least ping runs perfect. But later I found that the USB OTG HS CDC ...
DBaya.1 by Associate II
  • 2834 Views
STM32F407VG - SDIO / FATFS - save file to an sd card
Hi everyone,Sorry for this “Error while parsing Rich Text Content�?, I got an error when publishing. I can't share the whole file.Problem :> Even the card is present or not, The SD card is mounted .> I can’t write a file to the sd card.Context :I rea...
CFrom.1 by Associate
  • 764 Views
Resolved! STM32CubeMX & X-CUBE-USB-PD
Hello!I am trying to create my own USB PD device, but initially I want to test it using P-NUCLEO-USB002 kit. And I don't understand how correct install the X-CUBE-USB-PD library. I tryed to do it from CubeMX (V5.6.1), but there is no such extension i...
  • 1978 Views
HTML with LWIP
Hello community, I am working on a project for my science class and followed a tutorial online to get lwip up and running and I managed to switch my LED On and Off via my web browser.My question is I want to "save" a scene with a different button, bu...
STayl.3 by Associate II
  • 1300 Views
How to jump Application Address
I use STM32F205 seriesFlash Area is as follow : 0x80000000 ~ : Boot Area : 0x8000C000 ~ : Application Area.I need to solution how to jump Application area in Boot area source.Example, Now, state is Boot Area ( DFU ) , Enter for jump applica...
NH by Associate II
  • 1279 Views
