Updating STM32L4R5 System Bootloader
In device's errata sheet , we've found a statement 2.2.13 which says that MCUs with system bootloader V9.2 is not functional .But MCUs with system bootloader V9.5(date code after W05 2020) is functional.As of today ,for R&D purposes , we have 15 cust...
MichaelN by Associate
  • 1364 Views
USB audio class 2.0 device enumeration fails
Hello! I am working on designing USB audio class 2.0 device, based on stm32f722 with high speed USB external PHY USB3300. In USB audio class 1 mode the device works fine, but in UAC 2.0 mode device enumeration fails. Device descriptor and USB analyze...
EvgenS Po by Associate II
  • 1335 Views
Resolved! STM32CubeH7 MCU Package - where is version 1.8?
It looks like ST is changing the Cube MCU packages. Up to version H7_1.7.0 the old-style huge packages can be found on github (https://github.com/STMicroelectronics/STM32CubeH7/releases). But HAL drivers since v 1.8.0 are in a separate repository (ht...
Pavel A. by Super User
  • 2946 Views
Hello i have stm32f429I disc and i have a code which uses usb user connection.up to now i could use it but now I can't and doesnt seen in com ports
(there was a failure while reading analog voltage from a pin board is shut down and pluged out the ST-link connection.10s of secs it wouldnt boot and after a waiting and plug the power it booted and i can program it without any problem but). when i c...
AVara.1 by Associate
  • 668 Views
DFU mode STM32L475
Hello, How to set in DFU mode my STM32L475?Who to flash the micropython firmware .dfu?Where to find all the micopython commands in python to program wifi and sensors?Thans to be very precise in your answers please.Your sincerely.Julien
Jlaun.1 by Associate
  • 732 Views
Cheap way to add Wifi+Ethernet to an STM32 project
Hi dear community! :)My project is based on an STM32, probably one in the F range (have not decided fully yet).I would like to add Ethernet and WiFi to my project, ideally in a cheap way (in terms of manufacturing costs, for let's say 1000 units), I ...
SLasn.1 by Senior
  • 13931 Views
  • 16 replies
