Hi i have an Nucleo-L073RZ eval board need to implement sd card +spi + fatfs on it, i have attached a microsd card slot to the eval board , using Sd card 16GB SDHC . I have referred many projects from online for STM32F0 board .
It does not work on my eval board not even able to mount the sd card. Is their any restriction or limit wrt to clock for implementing this since stm32f0 can have max 0f 72MHz wheras stm32l0 only 32Mhz. if so how can this limitation be overcome . ...
svii by Associate III
  • 836 Views
AUDIO RECORD - MEMS > DFSDM > I2S > FATFS > Ethernet
Hello everyone,I'm trying to implement an audio acquisition system based on some demos from ST's CubeHAL libs. I'm using the STM32F413-Discovery board as a target for this project. It has most of the peripherals needed to complete the job, LCD, MEMS,...
Zaher by Senior II
  • 1634 Views
