2025-08-22 11:45 AM
The Cube-AZRTOS bundles cmsis_os2.c implementation has potential NULL pointer dereferences. There are many lines of the form:
if (( attr->cm_mem == NULL) || (attr == NULL))in code that attempts to recover and de-allocate memory from a "create" call that failed. The order of comparisons should be reversed:
if ((attr == NULL) || (attr->cb_mem == NULL))This happens for different structure members, not just the cb_mem.
I've checked the F4 version 1.1 ZIP file and github repo, as well as the github H7 repo and they both have this issue. I suspect all versions do.
2025-08-28 3:10 AM
Hello @Bob S ,
Thanks again for reporting this behavior. I've escalated this to the concerned team for update on the future (under internal ticket number 216461).
Best Regards.
