2019-05-17 11:41 AM
I am searching for an MCU with dual Ethernet. Do any of the ST cores have dual ethernet? Thanks in advance.
2019-05-17 3:10 PM
Use STM32CubeMX to filter devices by perhiperals and you will find that - no, there are no STM32 devices with more than 1 Ethernet interface.
Andy
2019-05-17 3:10 PM
Andy
2019-05-17 3:25 PM
Thank you. I did that but there was not a count of number of Ethernet ports. I opened every data sheet for those with Ethernet but did not see any that had dual. Thanks for confirming.
2019-05-17 3:39 PM
Use KSZ8863 or similar (managed) 3-port switch with one MII/RMII and two PHY ports. With proper configuration and software, it can do pretty much everything.
2019-05-24 7:16 AM
The STM32F107 has an Ethernet port and is about $2. Could you perhaps slave that off your main processor using SPI to provide the second port ? It obviously will run a little slower but may work for some applications.
