2013-10-30 5:27 PM
I am using the ST-Link/v2 for the first time. I tried loading firmware and when I select ''Program Verify'' and then select the .hex file, I immediately get a pop up window with the following message, ''Encountered an Improper Argument''. What does this mean? #st-link2013-11-01 5:15 AM
Hi Eric,
You are using the ST-LINK Utility tool, true? What product are you trying to program? Do you face any issue when you use only ''Program'' (without verification)? -Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
