2024-11-08 3:32 AM
I need to purchase a development/evaluation board to perform my development activity. We had finalised to use STM32F765VGT mcu and i need a compatible eval board for that as i don't want too much hazzel to port code to targetted MCU.
I found this eval board, stm32f779i-eval. Is this compatible and requires less effort for porting or changing the mcu in the cubemx. Need support on this.
Regards,
Aashik
2024-11-08 4:33 AM
The nearest Eval board for STM32F765 is the STM32F769I-EVAL but I think STM32F779I-EVAL does the trick.
2024-11-08 3:52 AM
Seems compatible in term of software, if you go from STM32F765VGT to STM3232f779I.
But you need to double check from both datasheets according to your needs:
https://www.st.com/resource/en/datasheet/stm32f765bi.pdf
https://www.st.com/resource/en/datasheet/stm32f777bi.pdf
Mostly the Table 2 on both datasheet.
+ Check if your software doesn't induce some conflicts in term of I/Os i.e. IO configured as output in your firmware, but on the board it's considered as input (input coming from another circuit output).
2024-11-08 4:04 AM
Hi SofLit,
Thanks for the reply.
My target software is for STM32F765VGT, since no eval board is available for that MCU, I am looking for the nearest one to develop my firmware until our custom board is ready.
So you suggest STM32F779I is the closest one, and I can start my development activity with this board? Or you have any other Eval board which much closer than this? Because I need CAN, UART, I2C, ADC and other peripheral ready in the Eval board.
Will take care of the I/O's part.
Regards,
Aashik
2024-11-08 4:33 AM
