2022-05-26 4:37 AM
I want to implement writing of data on password-protected NFC 25 tag) ST25DV04K
In my case, I have enabled write protection on Area1 with password 1 set using the NFC tap App.
I want to use a known password to enable my Android and iOS to write the data on these tags.
Could you please point ot to the example or resources to implement this feature?
2022-05-30 2:15 AM
Hello
Our application is based on a ST25SDK you can find here:
https://www.st.com/en/embedded-software/stsw-st25sdk001.html
Each application Android/iOS is based on ST25SDK and provides features to manage pwd and you can find resources (Source code) here:
Android -> https://www.st.com/en/embedded-software/stsw-st25001.html
iOS -> https://www.st.com/en/embedded-software/stsw-st25ios001.html
As example and for Android , search in files for ST25DVChangeAreasPasswordActivity
and/or ST25DVChangePwdActivity ... ST25DVPresentPwdActivity (presentPassword) for guidelines.
In term of description, refers to datasheet for descriptions: https://www.st.com/en/nfc/st25dv04k.html
BR
2022-05-30 2:15 AM
Hello
BR
