2020-04-23 11:20 PM
Thanks.
2020-04-24 6:04 AM
Hello Diverger,
1.) For HW you will need a matching network from target matching impedance to 50 Ohm, a 50Ohm cable (optional) and a 50Ohm Antenna.
There are some threads in the comunity mentioning 50Ohm matching network configurations. We are releasing soon (next week) a new version of the ST25R Antenn matching tool which does this calculation for you.
2.) you have to propperly configur the Single and RFO bit of the "IO Configuration register".
BR Travis
2020-04-24 6:04 AM
Hello Diverger,
BR Travis
2020-04-24 6:09 AM
hint on the mentioned threads: You will find them by searching "single ended st25r3911b" and "50ohm st25r3911b". Different chip but same principles (and bits) apply.
Regards, Ulysses
2020-04-24 6:37 AM
Yes, I think I've done right for it. I designed the matching network in ADS. And I'm very appreciated for your work to simplify the designing procedure.
