2022-04-21 5:00 AM
Hello!
I am new to ST products and have recently ordered ST25RU3993 reader IC evaluation board. The idea is to use the reader for access control in a building. I was wondering if any electrical motor driver could be connected to the evaluation board?
The motor could then for example be used to lock/unlock an entrance gate. Any leads will be a great motivation. Thank you.
Kind regards
Shahbaz
2022-05-18 1:03 AM
Dear SRizv.1,
please let us know how we can support you. Best would be if you could formulate a specific question to blocking point which we could then address.
Cheers,
B
2022-04-26 1:38 AM
Hi Shahbaz,
to my knowledge no direct connections are foreseen. You could re-use some LED pins to drive something (e.g. protection diode + relais in order to drive a motor).
Are you using ST25RU3993-HPEV or ST25RU3993-EVAL?
Best Regards, Ulysses
2022-04-28 6:56 AM
Hi Ulysses,
Thank you for your reply. I have just bought the ST25RU3993-HPEV. I will be using it to read tags and try to control building access system with it. Any kind of help would be appreciated. I am a new graduate .
Kind regards
Shahbaz
2022-05-18 1:03 AM
Dear SRizv.1,
Cheers,
B
