2020-09-22 10:03 AM
Hi Everyone,
I'm designing an application with the ST25R95. It has several pins that are labeled as "NC".
To improve the PCBA lay-out, particularly the GND plane under the IC, I want to connect as many as possible pins to GND.
My Question:
Can the "NC" pins of the ST25R95 be tied to GND (Not Connected pins) or should I leave these pins floating (Do Not Connect pins) ?
Thanks in advance for sharing your insights.
Casper van Doorne
Pink Fluffy Unicorns BV
2020-09-22 11:36 AM
on the X-NUCLEO-NFC03A1 board, the NC pins 3/4/7/10/11/23-28 are connected to GND. See schematics in UM2479.
Same for the CR95HF transceiver board in the M24LR-DISCOVERY kit.
Rgds
BT
2020-09-22 11:36 AM
Rgds
BT
2020-09-22 2:03 PM
Well Brian, I guess that answers my question.
Thank you very much for your contribution!
