2016-03-01 11:36 PM
Is there any sample Apps read /write memory beyond NDEF file? I want to lock the NDEF file and then use memory beyond for proprietary usage. Thanks for kindly help.
#m24srSolved! Go to Solution.
2016-03-03 5:16 AM
Reading beyond the NDEF file length can be done with the ExtendedReadBinary command. Please refer to the sectionExtendedReadBinary command of the M24SR datasheet.
You might also find useful the application note AN4433http://www.st.com/web/en/resource/technical/document/application_note/DM00105043.pdf
, section 2.2 for more explanation on the command. Hoping this will help you. Best Regards,2016-03-03 5:16 AM
, section 2.2 for more explanation on the command. Hoping this will help you. Best Regards,2016-03-03 5:17 AM
I forgot to say we do not provide demo code yet for the ExtendedReadBinary
2016-03-03 7:19 AM
