2019-11-12 12:19 AM
2019-11-14 4:15 AM
you could use something like ST25R3911B with its Active P2P mode. E.g. if you open NFCIP1 tab on two ST25R3911B-DISCO you can easily achieve 11cm.
It uses full P2P stacks (LLCP+SNEP) implemented on GUI but depending on your use case you can also use without. Possibly the X-CUBE-NFC5 could serve you then as a good starting project.
Regards, Ulysses
2019-11-14 4:15 AM
Regards, Ulysses
2019-11-14 4:24 AM
Thank you. I am in R&D phase and any advice is very much welcome.
Dragan
