2024-07-22 5:27 AM
Good morning, I'm looking for the sources of the USB communication library for the CR95HF DLL, unfortunately the downloadable library is only for 32 bit systems, I would need the sources to be able to compile it at 64bit and eliminate the problem.
Can anyone help me solve my problem?
2024-07-24 12:50 AM
The source code of the CR95HF DLL 32-bits version will be provided to you in private.
Rgds
BT
2024-07-23 1:37 AM
if I am not wrong, the CR95HF DLL has been ported to 64 bits inside the Software Development Kit for ST25 (STSW-ST25SDK001) in ST25SDK-1.11.0\readers\st\resources\windows\x64.
Rgds
BT
2024-07-23 5:20 AM
The DLL is 64 bit, the problem now is that the exported functions do not coincide with those present in the old one.
Like:
CR95HFDLL_USBconnect
CR95HFDLL_USBhandlecheck
CR95HFDLL_getHardwareVersion
And all other function if i dump exported function:
Dump of file cr95hf.dll
File Type: DLL
Section contains the following exports for cr95hf.dll
00000000 characteristics
592E8352 time date stamp Wed May 31 10:48:18 2017
0.00 version
1 ordinal base
10 number of functions
10 number of names
ordinal hint RVA name
1 0 00001E70 Java_com_st_st25pc_model_rfReaders_st_STReader_antiCollision
2 1 00001500 Java_com_st_st25pc_model_rfReaders_st_STReader_connect
3 2 000015E0 Java_com_st_st25pc_model_rfReaders_st_STReader_disconnect
4 3 000014F0 Java_com_st_st25pc_model_rfReaders_st_STReader_echo
5 4 000015F0 Java_com_st_st25pc_model_rfReaders_st_STReader_getName
6 5 000015D0 Java_com_st_st25pc_model_rfReaders_st_STReader_isConnected
7 6 00001640 Java_com_st_st25pc_model_rfReaders_st_STReader_selectReaderMode
8 7 00002060 Java_com_st_st25pc_model_rfReaders_st_STReader_sendPps
9 8 00001FA0 Java_com_st_st25pc_model_rfReaders_st_STReader_sendRats
10 9 00001950 Java_com_st_st25pc_model_rfReaders_st_STReader_sendReceive
I can't find any reference to the old APIs of the previous version, this one seems like a totally different version.
Thanks
2024-07-24 12:50 AM
Rgds
BT
