2025-11-09 11:56 PM - last edited on 2025-11-10 12:28 AM by Peter BENSCH
I am currently working on a use case involving the ST25DV16K NFC and Phytec Pollux board for Wi-Fi credentials sharing and connectivity.
I came across the following Arduino library for ST25DV:
https://github.com/stm32duino/ST25DV
I would like to clarify the following points:
Can this library be used for I²C communication between the ST25DV16K NFC and the Phytec Pollux board?
The stm32duino/ST25DV library lists supported architectures — would it be compatible with the Pollux board, which is based on an ARM 64-bit architecture?
If not compatible, could you please share if there are any supported libraries or APIs for ARM64 platforms?
Looking forward to your guidance.
Best regards,
Pritha Suresh
2025-11-10 12:42 AM
Welcome @Pritha_Suresh, to the community!
First, let me point out that ST25DV16K is already on NRND (Not Recommended for New Designs) and has been replaced by ST25DV16KC.
To your questions:
Hope that helps?
/Peter
2025-11-10 4:42 AM
Hi @Pritha_Suresh ,
This post has been escalated to the ST Online Support Team for additional assistance. We'll contact you directly. This post will no longer be visible in the ST Community.
Regards,
Lina
