2024-03-09 9:41 AM
We are using WLC38RX and wish to configure register setting usign the STSW-WPSTUDIO . However we do not have the EVK. Can we set the registers in the app and save the file?
We need the basic config of 5V supply for battery charging, 100mA normal and 200mA fast charginf input current charging as we are using a battery of 280mAh. Can the battery power be known as well?
Right ow we are getting 4.8V charging with 5mA current. Rest of the settings can also be suggested.
2024-03-12 7:45 PM
Hi
We suggest you buy our usb-dongle use GUI tool and connect the wlc38.
And you can set the registers in the gui and save the file.
https://www.st.com/en/evaluation-tools/steval-usbi2cft.html
