2023-11-08 9:47 AM
On its datasheet, it says 100A typical for current limitation. Just to confirm this is 100A per channel. Thanks.
2023-11-09 8:18 AM
This forum thread was marked by the moderator as needing a little more investigation, so a Support case was created in your name and will be handled off-line.
