2024-04-28 12:14 PM
Hello all,
in whole datasheet for VN7050AJ is not mention about default state of pins SEL0 and SEL1, but there is information that those pins can be left unconnected. Is there an internal pull-down resistor which selects current sense for CS output?
(BTW, there is no table about configuration of combinations those pins, you can use deduction from tables to guess this combinations.)
Thanks for answer.
