2024-10-28 6:04 AM - last edited on 2024-10-28 7:20 AM by Andrew Neil
I have some questions regarding programming the development kit. We have configured a BMS IC and MCU using a 3-cell setup based on the development kit circuit. Our circuit replicates the schematic and pin configuration of the L99615, connecting cells to pins Cell3 through Cell5.
However, during testing with a cell simulator, we encounter an unknown fault that prevents us from performing charge/discharge tests. This fault does not match any described in the datasheet, so we are reaching out for assistance.
In our program, we enabled OVC_Enable and CSA_Enable, but we observed that enabling OVC_Enable specifically seems to trigger an unknown fault.
We would appreciate guidance on resolving this issue. Thank you, and we look forward to your advice.
Best regards,
