2025-10-29 2:57 AM - last edited on 2025-10-29 3:36 AM by Peter BENSCH
Hi, dear. Could you please help me find the datasheet for the MOSFET with part code GF329MB, as well as other compatible MOSFETs with similar specifications?
Thank you in advance for your help!
2025-10-29 3:40 AM
Welcome @manmohan, to the community!
This is (or was) the STP15810, which was discontinued in 2024.
As a replacement, you should be able to use the:
Hope that helps?
Good luck!
/Peter
2025-10-29 3:40 AM
Hope that helps?
Good luck!
/Peter
