2014-09-24 1:26 AM
I'm controlling my PMSM at zero speed. While I'm trying to move its shaft I don't want my motor to generate its maximum torque to resist my movement but the limited one. Everything went fine with classic control, but as soon as I tried to limit it's torque -- by limiting outputs of speed and Q-current PI controllers on some smaller values -- the motor started spinning (?!). I really have no idea how to accomplish described task, exept by limiting outputs of PI controlers Any suggestions?Thanks in advance!2014-09-29 12:01 AM
Ciao user.user
I don't think that limiting the Q-current PI is correct because in that whay you are just limiting the volatge applied in the Q axis (Maybe this is the reason why the motor start to spin). Try just to limit the output of the speed PI using the MC API (this usually works). Ciao GigiWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
