2020-02-26 9:33 AM
2020-03-09 2:11 AM
Yes, the smaller pin with smaller hole should be the gate. With the flat surface facing down and the gate pin oriented towards you, the pin on the right of gate pin is A while the left pin is K. This info is missing in the DS0642 - Rev 6 of the device currently available on ST website. I was able to verify the info from Ver 5 of the datasheet discovered through online search.
