2025-10-16 6:19 PM
Hi! I'm using the STP16CPC26 as an LED driver, but have a problem where all the attached LEDs initially flash when powering up. This is a problem since this is a UI with a large-ish number of LEDs and you get hit right in the face with the bright flash.
I've tried delaying /OE until after I've written all zeros, and I've tried delaying applying power (12V) to the LEDs until after all zeros and /OE, but without a complete solution. Delaying the 12V power helps, but there is always a tiny blink regardless of what I do.
Is there some way to ensure that everything is dark on power-up?
Paul
2025-10-17 5:59 PM
