2020-06-24 11:33 PM
Background
I'm using STP08DP05 to control the current (20mA) through some LEDs in my design.
I'm using these for illumination purposes while I take an image.
I'm finding some variation in the brightness of my image, and I think it might to do with slight variation in the LED current changing the brightness of the LEDs.
Question
The data sheet doesn't seem to suggest what the variation in output current is for a single output, should I expect it to vary between the min and max levels of the output current (19mA-21mA) over time?
