2010-05-25 8:41 AM
2011-05-17 1:20 AM
you can adjust the increment of the target speed increment/decrement by manually editing the source file MC_Keys.c parameter SPEED_INC_DEC (line 57). Resoultion is 6 rpm so to set an increment of 500rpm you should write there 500/6 = 83. Regards, BillinoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
