2020-11-17 3:02 AM
Hi all,
Am using STC3115 for my application and utilizing the online driver provided for stc3115 where I used only default values expect the BATT_CAPACITY in stc3115_Battery.h ,which changed that to 1100 mAh as per my battery (3.7 ,110mah).
Issue is that m getting voltage values correctly but for current m getting repeatedly the same as 4497 mA. where in Ammeter is shows around 60mA .Can anyone suggest what am I missing?
I have tried the OCV offset given online but no use so kept all as zero.
I got the driver file online so m not posting my code. Thank you in advance.
