2025-10-01 2:21 AM
I am planning to use the SPV1050 in buck-boost configuration.
According to the datasheet, in this mode the charging current (I_batt) has a minimum value of 30 mA.
I have two questions:
Why is this specified as a minimum value? Can the actual charging current in buck-boost mode exceed 30 mA?
Does this parameter limit the current drawn from the solar panel?
For context, my solar panel can deliver up to 110 mA (at 7 V_OC). I am wondering if the SPV1050 is suitable for this panel.
Thanks in advance,
