2021-08-04 3:56 AM
From the rest of datasheet and also from the test we have performed preparing a test circuit it looks like there is no pull-up on the output (as it should be for an open drain), if so please update the datasheet. Please confirm if we are right or otherwise please give further detail.
Some samples of STM6904SFEDS6F will be appreciated for the time lost in doing the tests. Thanks
