2010-04-14 10:32 AM
2011-05-17 1:20 AM
your corresponding AC mains should be 24/sqrt(2). By the way, I would suggest you to download the STM32 Field-Oriented Control GUI fromhttp://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&fam=110&doc=59
. Using this Graphical user interface it will be much easier configuring the STM32 PMSM Motor Control library. Regards, Billino2011-05-17 1:20 AM
my stater kit library is versi 1. i want seacrh GUI versi 1 too, bt i not found it..T_T
2011-05-17 1:20 AM
there are no GUIs supporting the FW library 1.0 (you should use excel file and manually edit the parameters file for that). If you bought the STM32MC-KIT we can try to separately let you have the MC FW library v2.0 Regards, Billimo2011-05-17 1:20 AM
