2013-02-23 3:58 AM
Is there any difference betweem ST1CC40 and LED2000 regulators?
I coundn't tell any difference based on datasheet info.2013-02-28 11:34 PM
the only difference between the two devices is a pin. In LED2000 you find DIM pin while in ST1CC40 you find INH pin.
2013-03-08 5:15 AM
Hi Serge,
differences between the DIMMING function and INHIBIT is that whit DIM device is already turned ON (internal logic), with INH device starts always from OFF --> ON. so for dimming function better to use LED2000. VincenzoWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
