2023-08-24
4:43 AM
- last edited on
2023-08-29
4:13 AM
by
Lina_DABASINSKA
Hello i want to use the LD1084 voltage regulator .
I need to build a decoupling networks on the inputs and outputs of it.
Is there are some recomendations regarding decoupling networks of this noise.
Or if you have spice model of this component?
Thanks.
2023-08-27 6:52 AM
Being a linear voltage regulator, if the manufacturer does not provide Application Notes document with the necessary subject, it may be interesting to search for application notes of other models of similar regulators.
https://www.ti.com/lit/an/slyt504/slyt504.pdf?ts=1693078991259
https://www.google.com/search?q=how+to+design+noise+filter+voltage+regulator+linear
