Power management
Resolved! Diode BMY
Hi can someone help me with identification a marking diode ?
SimonB by Associate
  • 1112 Views
Reverse Polarity with ST1S14
Hello I have created reverse polarity but it can not work stable especially in the first work , this time I change the voltage a little bit it works :) ı cant understand. What should ı do?
EN11 by Associate
  • 965 Views
Need help with a custom USB-C device
Hi,I am trying to develop a custom USB-C based sensor accessory device for phones and tablets. Overview : 1 x USB-C male plug that will directly connect to a tablet, the accessory device will get power from the tablet, and a STM32F411 will send conne...
ninjax8 by Associate II
  • 3715 Views
Resolved! STD10P10F6
Edit by ST Moderator: This post has been translated from Japanese to comply with the ST Community Terms and Conditions (§10.2).. STD10P10F6 I would like to ask a question about the following. Do you have documentation showing the location of this com...
senda by Associate
  • 3883 Views
Resolved! Inquiry, powering EVSPIN32G4 with 6V & current sensing
Dear Community,We are considering using the STSPIN32G4 to integrate and control the motor in our system. The primary reason for selecting it is that our battery supplies 6V-8.4V, which falls within the STSPIN32G4's 5.5V-75V range.We have a few questi...
Sheng123_0-1738419300298.png Sheng123_0-1738421285009.png Sheng123_1-1738421336872.png Sheng123_0-1738419376246.png
Sheng123 by Associate II
  • 2629 Views
SMPS power supply Design
How to write software code to design 2 KW fully digital AC / DC power supply by using STEVAL -1SA272v2 Evaluation board. After writing program how I can design SMPS.
Bp2 by Associate
  • 879 Views
Resolved! The A7987 chip output terminal has high pulses
The output status of A7987 chips varies from batch to batch. We purchased materials from different suppliers, and one batch will have a high pulse of about 7V after recovering from a 5V short circuit, while the other batch will have a high pulse of a...
lindagu_0-1737608868097.jpeg lindagu_1-1737608868113.jpeg lindagu_2-1737608868122.jpeg lindagu_3-1737608868127.jpeg
linda-gu by Associate II
  • 2670 Views
