Power management
L9907 Does Not Work
Posted on April 07, 2017 at 08:26Hi ,I followed the link http://www.st.com/content/st_com/zh/products/evaluation-tools/product-evaluation-tools/automotive-ic-eval-boards/eval-l9907.html  and imitate the L9907 schematic to create my own PCB pad ,usin...
STEVAL PCC009V2 & SPINFamily Evaluation Tool
Posted on April 04, 2017 at 17:25/********* This question is also asked at ''Power Management and Motor Control > Discussions'' *********/Hi,I am trying to use the STEVAL-PCC009V2 & EVAL6470H boards using the SPINFamily Evaluation Tool (Version 3.2)...
[ATT]8059
Posted on March 30, 2017 at 02:33Alternate Method to Characterize Stepper Motor for Voltage Mode Drivers Application note AN4144 describes a procedure to characterize the stepper motor for use with their voltage mode driver such as the L6470. This p...
Error simulating the VIPer17HD
Posted on March 24, 2017 at 13:35Hi,I have downloaded the PSpice model of the VIPer17HD and when I try to simulate with Orcad 16.3, It gives and error: ERROR -- Invalid device in subcircuit.This error is repeated for each line in the .lib.How can I ...
Terminal Emulator COMM and X-CUBE SPN11
Posted on March 20, 2017 at 20:21Trying to communicate to a X-Nucleo IHM11M1 demo board and the Nucleo-F401RE using Tera Term and the IHM11M1 does NOT respond to sent commands.  I am running the X-Cube-SPN11 software sucessfully by uploading it to t...
How to optimize delayed Turn-off with SRK2000
Posted on March 22, 2017 at 14:35Hello everybody,I'm working on a power supply with a LLC Stage in it. The LLC has following specifications:Uin: 385VUout: 28VIout: 5.75ASwitching Frequency: 300kHzFor the secondary side rectification I want to use a ...
STSPIN Servo drive
Posted on March 10, 2017 at 14:31Hi would it be possible to use STSPIN3201 to build BLDC servo drive.Basic spec step and direction input, quad encoder input. Any help greatly appreciated. Thanks Paul
