Power management
VNQ5E160AK-E (new design) vs. VNQ5160 (old design): can current sense pins stay unconnected (and CS_DIS set to GND via 10k resistor), so the old PCB design can be kept?
We are using VNQ5160 in a project, but those chips are now not avalible and we would replace them with VNQ5E160AK-E. Footprint and switching power is the same, the only main difference is in status pins, where older chip has status outputs and new ha...
GMace by Associate
  • 1361 Views
Transil device in continuous operation
Hello.We are using a 1.5KE series Transil component (1.5KE300ARL), for protecting a device in continuous operation.We have some doubts regarding thebehaivour of the Transil in continuous operation. The power dissipation is very low (it only works abo...
GCalv by Associate
  • 665 Views
Another reference for the transistor "P52N90FI"?
Good Morning!Would you like some help finding another reference for the "P52N90FI" transistor? I have tried to buy in several stores but nobody knows this reference, they say the values ​​are high. Does anyone know of a website or any other transisto...
EDuar by Associate
  • 1091 Views
SW4ST build of X-CUBE-SPN7 demo project
Posted on June 11, 2017 at 20:47♯ build using ♯&sharpen.X-CUBE-SPN7.zip  Running an up-to-date Eclipse Ac6 session here is what happens when I try to build the &sharpX-CUBE-SPN7 demo application:1.select  File menu item2.   select Open Projects from...
PowerSTEP01 bring up procedure
Hello, I am a hardware engineer working with PowerSTEP01 device. I would like to ask you if you know is there any bring up procedure or some basic fundamental code which I can use to see if the stepper motor driver is properly implemented from HW sta...
Wrong pins. How and Why is my L6205 still working?
Hi Everyone, I've been using the L6205 IC on my robot pcb for at least a year to control 2 motors, but only today i discovered that i am using the wrong pins to drive them. Let me explain this better: i am using a LAP mode to control every motor so, ...
FGala by Associate
  • 957 Views
