Power management
package is not found
Hello ST Team,i am developing some projects and i need Energy management chips.. i bought the X-NUCLEO-IPS02A1 and the NUCLEO-F401RE so i could you use your examples in thepackage X-CUBE-IPS02A1.The Problem is i can't download the software package be...
Questions STC3115
Hello,I have two questions conerning the stc3115:Is it normal I have to send a soft reset to update the SOC ?When I am refueling the battery, the SOC is automatically updated to 100%. How can I avoid this behaviour ? Do I need to disable the charger ...
emil28 by Senior
  • 563 Views
Configuration advice stc3115
Hello,I have an issue on my stc3115, I can read the battery voltage and the SoC, but the SoC doesen't update (the voltage is udpated well).Here is the schematic of my PCB:For the moment, I am using a battery with two wires, "therm" is left floating. ...
emil28 by Senior
  • 744 Views
