Power management
STC3100 with Arduino
Dear ST-Fellows,I'd like to use the STC3100 with the Arduino IDE but my knowledge is too little to get it working. I looked at the libraries provided here:https://github.com/st-sw/STC3100_GenericDriverCould you please tell me how to adapt the files t...
MBobi.1 by Associate II
  • 917 Views
How to Avoid OverCurrent Error using STSW-SPIN3204 Library ?
I am using STEVAL-SPIN3204 development Board & using STM motor Library STSW-SPIN3204 .I am using a Maxon Motor with 12V DC input voltage.I am successfully able to run motor at 14k RPM but when I try to run motor at 25K RPM , my motor stalls & hits ov...
ASing.41 by Associate
  • 997 Views
Resolved! STEVAL-STSPIN3202 eval board not found on OSX
Hi,I have a STEVAL-STSPIN3202 evaluation board and trying to setup the environment on MacOS. When I plug in the eval board with a USB B cable to my MacBook, I don’t see a device in both ls /dev/tty* and ls /dev/cu*No devices even when I do, ioreg -p ...
VChan.2 by Associate II
  • 3145 Views
