VN7007ALH - Suitable for Industrial 24VDC systems?
This is an automotive spec power switch rated up to 28V. Can this part be used in an industrial system with continuous 24V supply at 30A?
Hi,I'm htinking about using STNS01 as my linear charger. However I need to know how can I turn off the BATMS since it will consume a lot of battery during. Furthermore, my battery does not have any NTC, so I don't need this pin. Can I left it unconne...
Hello.How can i use active miller clamp function of STGAP1AS mosfet driver for paralleled mosfets?
I'm looking at the IHM03A1 stepper driver board, which claims to handle 10A per phase. However, it's documentation says it only has .1 Ohm 2 W current sense resistors. Wouldn't that only be able to handle ~4.5 Amps of current?https://www.st.com/conte...
I am using STC3115 on a custom hardware. We have followed the reference design as suggested by ST and also used the driver suggested by ST. I am facing the following issues with this setup1) Sometimes (very rarely) the STC3115 is not able to detect...
L7987L switch mode power supply battery charging application. My plan is to have a rectifier followed by the L7987L buck-converter then a rechargeable battery. There is some protection provided by the Colomb counting current sense resistor.My questio...
