Power management
Resolved! Hello my name is Vicente I work un CONACYT MEXICO and am Electronic Engineer Actually I need Reliability Information of some components. No,part SMB6F70A STTH1R06AFY STMicroelectronics LM2904PT STMicroelectronics
The Reliability information consist in MTBF/MTTF or FIT of each component with a base temperature and Reliability test information.Thank you for your helpbest regards
GPere.21 by Associate II
  • 1687 Views
STEVAL-IPMNG3Q : purpose of EM_STOP signal
When connected to te STM32303E-EVAL board the EM_STOP will be connected to either PB7 or PE15 of the MCU.In my humble opinion the EM_STOP should be connected to the TIM1 BRK function , but neither of these pins can provide the correct functionality.A...
PVerh.1 by Associate
  • 811 Views
Suggest MOSFET for motor control application using VNH3SP30
I want to control a motor using VNH3SP30 driver IC. For that, application schematic is given in PDF(19th page) given in below link (from ST microelectronics website).https://www.st.com/resource/en/datasheet/vnh3sp30-e.pdfHere I want to get the sugges...
RKart by Associate
  • 861 Views
Limited connection initiation distance with STWBC-EP
To whom it concerns,For our wireless charging base, we attempted to effectively copy the STWBC-EP development board (STEVAL-ISB044V1). Although our base seems to work, the minimum connection distance is far shorter than the devkit, in fact too close ...
AMatt.3 by Associate
  • 819 Views
