Power management
Motor control using external microcontroller
Hello everyone,I'm developing a BLDC FOC Control System with STSPIN32F0. I want to control the speed via a host microcontroller. I want to use or PWM and a direction signal or UART. Which of these is the best way to do this? And what is the easiest w...
MBarr.2 by Associate
  • 804 Views
SPV1050 and undevoltage protection
I'm working with the SPV1050 Evaluation Board (STEVAL-ISV020V1) and I'm doing first tests. Undevoltage protection is set to 3.7V. But, what does it happen if a battery is below 3.7V? It seems it is never charged, right? How can I charge a battery tha...
B-G431B-ESC1 Quadrature Encoder Generation Error
I'm getting an error "Final current ramp value is higher than motor nominal current" when I enable the quadrature encoder option in speed sensing (either as the primary or auxiliary sensor). As per another thread and the schematic, I have reconfigure...
MWild.3 by Associate II
  • 816 Views
