is the A6985F SYNCH/ISKIP pin connected to a pull-up or pull-down?
Hi, the datasheet pag. 29 says:When the A6985F is configured in the low consumption mode, the SYNCH/ISKIP pin operates as a logic gate input pin with an internal pull-down (4.5 μA typ) guaranteeing the ISKIPH operation when leaving the pin floating.b...
