Power management
SPV1050 - 100mV on BATT pin and no output on LDO2?
Hi! I'm working on a project using SPV1050. The configuration and schematic for my device is as on the schematic below. I'm providing 4.3V on line PV+ (pin20), yet I have only 100mV (not rising) on BATT pin and absolutely no output on LDO2 pin. Why c...
PSław.1 by Associate
  • 1198 Views
Resolved! TVS bidirectional diode
A TVS bidirectional diode labelled as GMK GP401. What would be the value of the TVS diode? Thanks
Hercules by Associate
  • 1777 Views
Why does the LD39050 have a maximum capacitance value?
We have been seeing some intermittent failures of the LD39050 in our products. I can't see anything wrong with the design other than the output capacitance. The datasheet specifies a maximum of 22uF for stability, but our design has approx 30uF on th...
MAlde.3 by Associate
  • 1142 Views
Resolved! EVLPOWERSTEP01 Board Bill of Material & Technical Queries
Queries:1. Could you please provide us manufacturer part numbers of all parts/components used on Evlpowerstep01 Board.2. Provide shunt resistor 0R1/2W tolerance value.3. Provide all decoupling capacitor type?4. Value of Capacitor Cp used on evaluatio...
