Resolved! Can LED2472G be used as a shift register to drive signal relays?
Can LED2472G be used as a shift register to drive signal relays with coil current of < 30mA. Can they be used as generic shift registers too?Thanks!Håvard.
Our company received these transistors, which have not rectangle under marking code. Is it fake for sure ? Duplicate is on the left side of picture , original is on the right side.
Is there a way to cross top marking code with component reference? I am looking for the diode marked as the photo below.
