Power management
How to perform High-side switching of N-channel IGBT (STGW20NC60VD) if required gate-voltage is greater than the rated max gate voltage?
I am building an PV module I-V tracer that makes use of a capacitive load. In order to trace/record the current and voltage characteristics of the solar panel I am measuring the voltage and current that develops over the capacitive load as it charges...
Moh by Associate
  • 1575 Views
Resolved! how STLD40D Driver work?
Hi everyoneI'm going to use STLD40D Driver IC for my TFT LCD. For driving LCD backlight, I'v chosen this Driver from ST. But I can't figure out the function theory of this driver. could you please explain for me the STLD40D function theory and how to...
MSm by Associate II
  • 3091 Views
TPS1H100B Counterfeit/Fake?
We have some prototypes with TPS1H100BQPWPRQ1 on them, but the IMON signal isn't performing as expected. Does anyone see any issue with part in attached photo?We were told the TPS1H100B would be a drop in replacement for the TPS27S100B, but after swa...
Paul1 by Lead
  • 2283 Views
