Power management
STCS1PUR went flashing after connected to power. Need a solution.
I am using the same schematics as the datasheet's typical application schematics sugguests. The EN and PWM pin were tied together with Vin. When I connect it to 12V power, It went steady for a couple of seconds then it starts to flash, it turns off a...
TSu.1 by Associate III
  • 733 Views
I am using STCS1APHR constant current LED driver but at the time of powering ON the supply,Led blinks (turn on ) momentarily need a solution on that...
Hello,I am using STCS1APHR constant current LED driver.CASE 1: I pull up Enable pin to VCC and pull down pwm pin to GND with 10K resistor.CASE 2: I pull Down Enable pin to GND and pull down pwm pin to GND with 10K resistor. But in both cases the l...
Apati.19 by Associate
  • 1320 Views
